An aligned material is not aligned while rendering
Hey!
I'm trying to figure out why my facade material is still wavy after i aligned it under the texture settings.
It starts when i start rendering and the outcome is this:
[/img]
I really glad if someone can help me!
Thanks
2 Replies 2
Emre Senoglu
Hey Sandra, looks like your render resolution is way too low to be able to clearly see a repeating texture that far away. You should try increasing your render resolution and rendering again.
AC27 ARM // MBP M2 Max // Twinmotion | Corona | Rhino
senoglu.co | archimats.com
runxel
We just had the same exact thread
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
