2004-10-02
10:09 AM
2023-05-11
12:41 PM
Noemi Balogh
2004-10-10 11:25 PM
2004-10-11 12:17 AM
2004-10-11 12:34 AM
bill wrote:This rebuild technique doesn't work for me. You must keep in mind that it only renders with extra lines when shadows are on in the sketch renderer (and when you don't rebuild before rendering the same image without shadows after rendering it with shadows). I am almost positive that this is a program bug, because it was like this in version 8 and 8.1 until it was fix in the last or second to last update to version 8.1.
a rebuild immediately before you use the sketch renderer seems to kill the extraneous lines
bill
2004-10-11 01:22 AM
2004-10-11 02:29 AM
2004-10-11 03:06 AM
bill wrote:Bill you must note that I am talking about ArchiCAD 9 not 8. In version 8 it has already been fixed so you are correct. My comment was that it seems to be back in version 9. In ArchiCAD 9 vs 8 the sketch rendering engine w/ shadows is over 600% faster. To me it just wasn't practical to wait hours for sketch renderings w/ shadows in version 8 at such an early phase of a project. With ArchiCAD 9 it is because on larger projects I've seen speed increases over 1000%. For now I just use Photoshop to get rig of them and even thought I've only had ArchiCAD 9 for a week I've already saved many hours of sketch rendering time.
michael
a rebuild works for me (ac8)
if it doesn't work for you then, yes, it's probably a bug
bill
2004-10-11 05:52 AM
2004-10-11 12:14 PM
wr1nkles wrote:It might also bve that the 3ds-file which contains the ArchiCAD sunlight is giving a spotlight on a long distance and with a very small lightcone. Delete it and use a sun/spot of Cinema4D instead.
next question, why is it black when i render it?
thanx
2004-10-12 11:42 PM
2004-10-13 12:45 AM
