โ2005-01-06
02:46 PM
โ2023-05-11
01:46 PM
Noemi Balogh
โ2005-01-11 11:38 AM
โ2005-01-11 01:02 PM
โ2005-01-31 05:44 PM
stefan wrote:(Yikes!!!!!)
To create GDL objects, export to 3ds from Lightwave and import in ArchiCAD as a Library object.
โ2005-02-01 11:07 AM
Bricklyne wrote:The import plugin exists (but is hard to find).stefan wrote:(Yikes!!!!!)
......that wouldn't work. He (She?) uses ArchiCAD v7, that doesn't import 3DS objects/files without the import plugin. I suggest you try to find the 3ds-import plugin to import the objects into ArchiCAD. I believe there was a link to a download site somewhere on the forum. I'm not sure about whether or not there was one for version 7; I'm pretty sure that there were some for versions 8 and 8.1, in German however. Alternatively you can just upgrade to ArchiCAD v9 which has the 3DS import version built in and in English ( if that is yourLingua Prefere) plus it has a ton of other upgrades and optimizations that you'll just lovecoming from version 7; not to try to plug it or anything. ![]()
As for importing from ArchiCAD to Lightwave, once you're done with all your modelling in ArchiCAD then export from the 3D window as a LWO or OBJ object. I believe Lightwave accepts both formats, but I'm not sure which is preferable for rendering pruposes since I haven't used Lightwave in a very long time.
โ2005-06-27 06:56 PM
stefan wrote:Hello Stefan
โ2005-06-28 09:26 AM
โ2005-06-28 09:36 AM
โ2005-06-28 09:39 AM
โ2005-06-28 09:54 AM
stefan wrote:Yes, I find some site with lightwave object โlike this one http://dmi.chez.tiscali.fr/models16.html โ and like to use it on ArchiCAD
Are you saying that you have a Lightwave object you want to import, but you don't have Lightwave?
stefan wrote:Does this conversion programs are freeware or not?
There are conversion programs to do that, so for a one-time conversion I want to give it a try.
