Djordje
Archicad 25 Datasmith loses connection to TwinMotion 2022.2.3
As noted... 3D open in Archicad, TM started, no connection... cannot update the model, cannot relink the Direct link, cannot import Direct link...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
3 Replies 3
Emre Senoglu
Please read here: https://twinmotionhelp.epicgames.com/s/article/Datasmith-Exporter-Plugin-Installer-Common-Errors
If you still experience problems try contacting TM support.
AC27 ARM // MBP M2 Max // Twinmotion | Corona | Rhino
senoglu.co | archimats.com
Djordje
thanks, Emre... TM support contacted immediately
Djordje
HP Omen
Djordje
Interestingly… I have installed the 2023.1 preview, and there the live connection works. Will try to uninstall and reinstall 2022.2.3 and see what happens…
and speaking of support… Graphisoft could do worse than see how TM does support. Talking about the setup. Clear and easy to navigate portal, quick followup. While this here is a form of support, sharing advice is one thing, regardless of the quality of the advice, and providing professional tech support by the vendor is another game altogether. Been there, done both.
Djordje
HP Omen
