Our customers might be experiencing service disruptions due to a global outage at Microsoft Azure. Our team is actively monitoring the situation and working to minimize the impact. Thank you for your patience and understanding.
Visualization
Archicad 25 interior sink bowl to twinmotion material issue.
jmaul01
Anyone experience this problem and a have a solution or work around.  Interior of the sink bowl goes missing in twinmotion.  No SEO on the sink and the sink and cabinet base, which is a slab, intersect one another.  Archicad 25 Sink object.  Can't control inside of sink material in Archicad or apply a material to the inside of the sink in Twinmotion.
Thanks,
Jim
Windows 10.
Archicad 25
Twinmotion 2022.1.
I don't use Twinmotion enough to remember the correct terminology.
But I think in Twinmotion you can set a material to be double sided - or something like that.
Nailed it Barry!!! Thanks so much.  Just getting in to twinmotion as well.  Thanks again. Jim
