Artlantis R
I am trying to save a jpg in ArchiCAD to an .atl so that i can open the image in Artlantis, but there is no option to that when i save as! I do appeartantly have the add-on to send out an .atl. Can someone help?
I am using AC10
1 Reply 1
Dwight
You use the Artlantis plug-in to save actual Archicad 3D files to Artlantis. From the 3D window "Save As" ---- Artlantis...
If you should need to open a jpg as a rendering background or material surface, you can do that directly from Artlantis.
Plug-ins here:
http://www.artlantis.com/index.php?page=download/plugin/index
But you can't save directly to Artlantis 2.0 from Archicad 10.
Dwight Atkinson
