Visualization
Artlantis ..or LW AC 9
In my opinion Artl. is very good for interior (LW is too dificult to check the light)
For exterior LW with AC is absolutly better than artl.
What is your opinion?
Please help me.
Now I am considering to buy Artl or not...(in Germany bargainsale for 100 € for AC9 buyer)
20 REPLIES 20
I have much time now, because the building contract situation hier is very terrible.
I decided to buy Artlantis because:
The function of prallel objection (for elevation and so on) is very nice.
very easy to control interior lighting (generall light object)
separated work is possible.
materila change with image data (like JPEG) is very good.
100€....I can pay (because I stop smoking,)
LW makes me very angry! (even thogh ..still I love LW...)
But I must drill LW because:
Window light object and rendering color from LW can show nice atmosphere.
I can take tipps from nice guys (like Dwight).
At least but not last:
I wish, Update of LW in direction to easy using.
With sun light and window light and sky light object are very slow with rendering time.
Steve Jepson
Thomas wrote:
The only workaround I've found is to create one material (identical, but with unique names, both for the material and the duplicated texture map) for each side orientation, and apply them individually. Too much work, compared to using Lightworks, where materials orient themselves correctly, perpendicular to the surface on which they're applied!
Perhaps someone knows if this is fixed in Artlantis R. If not, I'll probably jump the upgrade, radiosity or not.
Or perhaps someone can tell me what I'm doing wrong?
You may find it easier to give each surface a different color in ArchiCAD. Roofs for example, give each roof plain in the view a different color) then in Art*lantis you can drag&drop a texture and rotate it as needed. It also helps in getting the shade just right when adjusting the light is not an option.
Thomas Holm
Thanks, Steve, good idea, and problably simpler. Still a workaround, though, I would have to re-apply after every re-omport from Archicad. Nobody knows if this is fixed in R?
Those who know cannot speak...
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Dwight
However, here's a cryptic clue that won't violate anyone's NDA, eh?:
"Those who can speak do not know."
Dwight Atkinson
Any 3D modelling and rendering software is difficult to learn. Or it may not be so difficult but it definitely will need a very long time to get used to it and to try all the option and tools it provides.
I myself have always wanted to learn Maya and recently I tried it - it is definitely much easier to navigate and more interactive than MAX but I just did not have enough time, so I gave it up.
My advice is to get some 3d software - they all produce good images nowadays. For really smashing presentations you will need some plug-in like VRay or Brazil, etc.
stefan
Thomas wrote:
Guys,
one reason I've ditched Artlantis for LW (for now) is the texture mapping quirks in Artlantis. When i for instance want an identical wooden panel siding, created by using a material with a striped texture map, on all four sides of a house, I can't use one material for this, because it orients itself after the first instance applied. (This is easier to show than to explain with words, but being home at the moment I don't have an example at hand).
This mapping gets it right on the front facade of the house only (if that's where I applied it first). On the back, it's mirrored. On the right and left sides, a one pixel column of the texture map is spread all over.
(I think Dwight has explained this better somewhere).
Is this still a problem in Art*lantis? That was my first and most important gripe with the software and one of the main reasons to never use it! Back in 3.1 or so there allready were mapping problems.
I have Artlantis 4.0 but never use it.
Lightworks is a good engine but the interactivity of Art*lantis can't be beaten in most applications. ArchiCAD just lacks the speedy direct interface (you need to open several dialogs and close them again to simply change one single parameter and render again). So for exploratory rendering and trial runs, this is not working. If you have a basic set of common materials, you don't need to tweak all the time and then the LW combination is very good. I think it really requires some material-library template that makes it usable by any ArchiCAD-user so it can be put to good work without much effort. I think it is possible, but not without major office-preparation.
Archicad-user since 1998
my Archicad Book
stefan wrote:
Thomas wrote:
Guys,
Yes! That is the point.
Those who know cannot know (*)
1) Export plug to Atl file ... Clearly the situation :
In the past the Artlantis 4.5 export plug was made by Graphisoft when for technical reasons, the texture orientation was difficult to realize (not impossible but difficult)
1 bis) Export plug for Artlantis R
Abvent is re-writing of a new plug for ArchiCAD.
The first version of this plug wil resolve parameters bugs existing in the old one (smoothing parameters is an sample)
and preserve the texture orientation and scaling with uv mapping as we done in the defaiting av-works add-on.
The second version will increase a lot the link but ...those who know cannot speak.. :O) toom any people in this forum
2) Artlantis ..or LW :
It's not the right question. At Abvent, we pay attention to the Architects need and the right tools to achieve it.
Remember that since more than 15 years, we sell ArchiCAD and Artlantis we also sell Artlantis to Vectors works users who have LW since a long time. (be carrefull LW raytrace is not LW radiosity it's very different technology to implment in a software.. .we experiment it last year in Artlatnis, but I cannot speak about that)
As ArchiCAD distributor, we are very happy that the new rendering basic level of ArchiCad is at the same level as competitors.
BTW , this will increase the rendering market around ArchiCAD and the Artlantis R market of course.
There is objectives reason to use internal render and other objective reasons to use an external tool.
Artlantis R is one of the candidate, of course we hope that its new features make it the most popular rendering companion for ArchiCAD, despite the ease of use, the new technology and inovator productivity feature, there is also technical and economical reasons to use external tool, just few arguments
- For large file , manipulation in CAD software become difficult, you get memory limitation etc...
- With external software, you can use a second computer to render and continue to work with your main CAD on the other one.
- Radiosity on one click is really new step in seeting the scene.
(see the attached picture..setting 15 minutes šŸ˜‰
no way without radiosity
Of course I can continue to explain what are the advantages to use external solution... and Artlantis first , but I will be too long.
(*) not available for our beta tester at this time ...sorry guys
we do our best to deliver it at launching
... ATL file are always compatible ...
have a nice day
Gerard
I am using over 10years or more AC, and AC-user is used to think automatically in 3D, that means, for AC-user image is all.
During working process I check in early stage material image with 3D environment. It influence very much concept.
That means, the concept itself, in one programm to check material (with LW) is nice concept. And final rendering course with Artlantis is the next stage.
Graphisoft must consider to categorise or standardise the lighting or material shader options with LW, so that the user can use very easy (first of all in a very short time).
Is ther any information, how much the updat to Artlantis R costs?
