Visualization
C4d 14 and Archicad 16
I have a problem when i try to update a project from c4d and archicad ... in merge command will update only the new geometry but I lose all material mapping ... I think the plug in it's not upadte for last release of c4d !!!!!
1 REPLY 1
Eduardo Rolon
As far as i know the plugin does not update the materials for that you should look into getting.
http://din3d.net
That is the one I use.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
