CINERENDER - REFLECTION ISSUE
I am rendering a building in Archicad 21 and I am having an issue with the surface settings. The soffit lining is a white colour and it seems to be showing some type of reflection from the grass ground surface. Does anyone know how I can turn this reflection setting off as I have tried changing all the settings but nothing seems to work. Has anyone else had this problem and been able to fix it??. Any help is appreciated.
Chris
1 Reply 1
Carstenem
part of it is the sample count which is really low. Then check the discrete area and sky sampling. See images attached. Let me know if that helped.
Cheers Carsten
Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
