2022-07-21
10:32 AM
2023-05-11
11:20 AM
Noemi Balogh
HI,
I can't render in 3D, CINEWARE keeps crashing.
Also, I downloaded a .jpeg of a material surface and created an new surface (please see attached). (cement sheet)
In the model when textures are turned on it looks great. But when I rendered it goes a spongy yellow colour??
(this was before Cineware was crashing.
Solved! Go to Solution.
2022-07-21 11:15 AM
2022-07-21 10:47 AM - edited 2022-07-21 10:52 AM
@cadsph wrote:In the model when textures are turned on it looks great. But when I rendered it goes a spongy yellow colour?
The 3D window uses the basic engine which have different settings than the Cineware engine which likely is why you get a different result. The Cineware engine is more advanced and requires some knowledge to get a good result when creating surfaces.
2022-07-21 10:52 AM
What are your machine specs, in particular your video card?
Have you updated video drivers?
Have you tried rendering just a single wall or slab - something very simple?
2022-07-21 11:09 AM - edited 2022-07-21 11:10 AM
I got into photo-render settings & manged to get it working,
I've uploaded an image of the yellow texture from the .jpeg.
when I use Basic render it comes out the right colour (graphite).
Does anyone know why the texture turns yellow?
2022-07-21 11:15 AM
Try using the Match Settings > Update Cineware and see if it gets you a decent result.
2022-07-22 05:37 AM
Excellent! when I changed Engine to Cineware - I updated
the match settings from basic & it worked!
Thanks.
2022-07-22 05:41 AM
I've got a Asus Geforce 6GB graphics card on my desktop. So it should be fine.
I've never had a problem with CAD software crashing on my PC before.
but I'll update my driver.
2022-07-22 05:43 AM
Sorry refer to previous post for my reply
