Camera - first & second floor
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2022-10-23
12:30 AM
2025-01-31
12:59 PM
Molinda Prey
Please how can I record first and upper floors as I do record the ground floor with 'create fly-through'?. My problem is that I can only record the ground floor. I mean if I select first or upper floors and set the cameras in first floor, it always record the ground floor.
Works at an Architects Company using ArchiCad 21
Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz 3.19 GHz, 8.00 GB, 64-bit operating system, x64-based processor
Solved! Go to Solution.
- Labels:
Camera Tool
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-10-23 08:09 AM - edited 2022-10-23 08:10 AM
Eman,
you will need to set the camera height to eye height plus the elevation of the desired floor level above project zero
eg for my project. - 1550mm (typical eye height) + 4500mm = 6050 first floor
- 1550mm + 8700mm = 10250 second floor
Scott
MSI Creator ZP16, i7-12700H, 32GB RAM, RTX 3070 8GB
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Eman,
Scott
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-10-23 01:41 PM
Hi Scott, thanks very much.
