Visualization
Can't render on Artlantis 2.0 from AC13
There must be a problem with the translator with AC13 Artlantis 2.0 output.
When I opened the file on Artlantis, it was fragmented in millions of pieces... i could not even look at the preview to apply shaders and the render was talking 10x longer then the usual, and file was only 5Mb.
I had to save the file as AC12 and then export to Artlantis 2.0 to be able to finish my job.
Has anyone had a problem with that?
4 REPLIES 4
An updated export add-on was posted in December. Do you have that one?
http://www.artlantis.com/index.php?page=download/plugin/index
AC 28 USA and earlier   •   macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
the update only replaces Artlantis Studio 3.0... we don't have this software yet.
never mind.. i saw the one for Artlantis 2.0 from AC13!!!
Thanks
It turned out to be a Origin problem.
I have started the file from a DWG map base, with an origin VERY distant from the drawing and that was making the file impossible to work with.
The problem was solved by shifting the whole model closer to the AC GREY Origin.
I don't know how to explain why the same file was working fine when I saved the .atl from AC12... can anyone?
