Cinema 4D - The Industry Standard
Maxon has recently upgraded their flagship product, Cinema 4D to version 10. They have also released a plug-in for ArchiCAD 10. These programs make for a terrific pair, ease of use, mature feature sets, speed and wonderful workflow.
For several months I have been putting other software packages through my personal learning curve and user testing. I work with the software and post my experiences in threads like this at the Talk.
I enjoy the fact that so many views happen within the threads. Better yet, I enjoy when others kick in their experiences with the subject software. No need to butt in with examples from other software programs, it is more interesting to just fully explore a single package - which in this thread is Cinema 4D. There are many existing architectural users of this fine piece of software and I call upon them to post recent examples of (WIP) work in progress and final renders. Not everything is perfect and there are currently a few kinks in the plug-in, but I will get into explaining that later.
If this is your first introduction to C4D, trust me it won't be your last. Nemechek is the parent company of Maxon and the C4D suite. News is that Nemecheck is or will soon own GraphiSoft and ArchiCAD. Just put two and two together.
I'll start the thread with a quick example scene I assembled with bits and parts laying around on my hard drive. Tree entourage by xFrog, a snowy hillside from an example file on the internet, sky effect built into C4D, building from an ArchiCAD training file I use at the aBPa office in San Diego. All of this thrown together within 30 minutes, the render took 2 hrs. on a G5 dual 2GHz.
Cinema is the king when it comes to import/export. If you can get your entourage into practically any export format, chances are C4D will be able to import it. This is an extremely important factor to creativity. Now that I have gotten past my need to throw together something in C4D v10. It it time to slow down and create some examples of workflow issues, speed tests realistic rendering techniques. Once again I ask for help from other C4D users who can post examples, please jump right in - the water is fine and with a little MAXON soap you get a squeaky clean render.
Links to more info:
Architectural Examples:
http://www.maxon.net/pages/dyn_files/dyn_htx/htx/sol_archi_e.html
ArchiCAD related links:
http://www.maxon.net/pages/solutions/archicad/archicad_e.html
Achievements:
http://www.maxon.net/pages/dyn_files/dyn_htx/htx/press_e.html
54 Replies 54
Here is an example of a project designed by (Architects BP, Inc. - San Diego, CA) showing what makes C4D an excellent architectural program.
Architectural projects often involve doors, windows, walls, and then more doors, windows and walls. After a while a multi-building project will weigh down ArchiCAD to an absolute crawl. This project did, in fact I could not place more than 7 of the buildings into it within ArchiCAD before it became unbearable (8 min. refreshes, etc.)
Breaking the project up into individual building files, I exported them and the site into C4D. Quickly I was able to put it all back together and explore the site in Enhanced Open-GL. The typical rendering time is 3.5 minutes. This image attached is an radiosity solution that took 3 hrs. Not a whole lot of difference between the standard renderings and radiosity when your view is this far back. This same file caused Maxwell to slow way, way down. It just could not handle it.
C4D can handle this type of file with ease.
A close up of the original render.
Screen shots.
stefan
Did you use the "instance" object in Cinema4D? Or just plain copy-paste? Or is the whole site and buildings collected in ArchiCAD?
I'm asking since it would be good to have some advice to tackle large scenes efficiently.
Archicad-user since 1998
my Archicad Book
I have been using the "Cut & Paste" in C4D [the site populated with 1/3 the buildings became unbearable in AC] , I too would like to know more about instances / mirror - I"ll test it soon. So far not a big problem using the cut and paste method, I organize the file and turn off rows of buildings while exploring and composing. Everything works very quickly. I started with 12mb this morning with site and bldgs., have been adding cars, trees and ground cover and I am now up to 13.4mb.
From the manual: An instance object is a special duplicate of an object that does not have its own geometry. As a result, instances require far less memory than conventional duplicates, but the advantages do not end there. Imagine that you have created a street scene with over 40 street lamps (all instances of the same original object). By adjusting the brightness of the original lamp’s light, you can change the brightness of all lamps in one go. You may even edit the original with the modeling tools and the instances will follow suit. Material properties are adopted as well. Only the position, scale and rotation are independent of the original.
An instance object will not significantly increase the size of the saved CINEMA 4D file. However, the CINEMA 4D editor will still need to allocate additional memory as if the instance object were a non-instance duplicate. The Scene Information dialog shows instance objects to consume as much memory as duplicates.
stefan
I ask this because some rendering engines work more efficient using instances. They are called "blocks" in AutoCAD and also "instances" in 3ds max. Most 3D applications support the concept.
In your particular scene, it could possible improve the rendering time and since it is so large, any optimization would be noticed.
That is, if you have the time and patience to let it render again with instanced buildings...
my Archicad Book
Hi
I'm just trying out C4D. When I go File -> Save As -> Cinema4D and then try to open the file C4D says 'Unknown File format'
I'm using AC10 ver 1010. The plugin for AC was downloaded from the Maxon site today. And I'm using the demo of C4D R10. My Os is Mac OS X 10.4.8 on a Mactel.
Anyone got any ideas?
TIA
Adri
my mistake.
didn't read the installation instructions properly.
Adri
Well,
I'm just starting out with C4D but initial impressions are that it's harder to get to grips with than Maxwell.
Does anyone know of any tutorials for C4D used with Archicad?
We want to produce high quality renders but really important is that producing those renders doesn't add hours and hours of work for a single image. It's one thing leaving a machine overnight to generate the render but another if it takes a person the best part of a day to set up the scene in the first place.
Anyone got any links to tutorials?
TIA
Adri
adri wrote:
my mistake.
Adri
ALSO: Realize that you need the initial product [eXchange plug-in] - the web site is only an update. Without the actual product you cannot update a scene with new geometry.
See product at:
http://www.novedge.com/Page_Bookmark.asp?SKU=2093
