With your tests I got a little bit more confidenti with Cinerender (I've been using Maxwell and Artlantis). Cinerender is a good improvement in the workflow. It allows you to not waste time with settings and corrections outside the model in archicad ...
On the other hand ... well ... I need to improve my skills ... with tests tests and tests ...
I did some tests.
This is what I got (see the attached picture). It is the preview image but the final one is not so different from that one in terms of artifacts and general result.
I passed to AC19 from AC18.
IES are ok.
Materials with luminance (I put a square downward with a luminance material for each lantern) produce yet so many artifacts.
How to avoid those artifacts?
What's the parameter to play with in order to have a more decent light distribution from luminance materials? Is the AREA SAMPLING parameter?
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
