ā2021-05-21
06:29 AM
ā2023-05-11
11:51 AM
Noemi Balogh
ā2021-05-21 09:00 AM
ā2021-05-21 09:26 AM
ā2021-05-21 09:35 AM
ā2021-05-21 09:50 AM
Alammouri wrote:
And it not solved and I can't find uncheck solved checkbox
ā2021-05-21 10:41 AM
ā2021-05-21 10:50 AM
Barry wrote:Thanks Barry
It is the same button used to mark the post as solved (the tick).
ā2021-05-21 10:54 AM
mikas wrote:Nice Idea , thank you
Not sure if I understood it all, but I'll try.
Publish the renders to a folder, then import those renders as drawings to your layouts.
You would have to mind the order of publishing though. Renders need to be published first, and only after that the visualisation set - to get the latest published pics updated.
