‎2022-11-02 02:13 AM
Hello
I have installed twinmotion and the latest datasmith, when I imported the AC file I noticed some parts missing. They all have the same classification, same renovation filter, same layers, just perplexed on why only random parts did not transfer over. See attached image. Anything I am doing wrong?
‎2022-11-02 09:17 AM
‎2022-11-02 01:37 PM
Hello @emre, no luck with that option 😞
‎2022-11-02 01:45 PM
are using the direct sync? if so, you can try a exporting a datasmith file and then linking it in TM. this usually fixes most problems.
‎2022-11-02 08:34 PM - edited ‎2022-11-02 08:35 PM
‎2022-11-04 01:09 AM
Hi Emre, for soem reason my twinmotion crashes as soon as i try and open the file.
I first followed this proceedure:
https://www.twinmotion.com/en-US/plugins/Archicad
it was working fine, I swicthed from direct x11 to 12 and i think since then my twinmotion is irrelevant. Tried sending the logs to epic and they just refered me to the twinmotion page, lets see how that goes. Dont know that community or how active they are. 😞 really bummed I can do nothing with the software.
‎2022-11-04 01:10 AM
If i can ever open a file before it crashes ill try it. 😞
‎2022-11-04 09:22 AM
You should submit a bug on the twinmotion forum: contact form
They are very active & helpful - you will probably get an answer within a day or two, and someone from the team will follow you through until the problem is fixed.
I had a similar case once, and they were able to take my file, 'decorrupt' it and send it back to me. Don't worry, you can do a lot with Twinmotion and I'm sure they'll help you to find a way to fix your file.
‎2022-11-04 11:41 PM
Ok epic was helpful, but original issue is still there, if i understand your order would be:
1-make a datasmith file
2- in twinmotion open new import and and use that datasmith file to like the geometry tab
3- ??
I tried and that didnt work either.
