‎2009-11-0509:46 AM - last edited on ‎2023-05-1101:52 PM by Noemi Balogh
‎2009-11-0509:46 AM
I have a problem. I have to do an interior project in Archicad and I was wondering if it's possible to use your own photo on some furniture.
For example, I want to use a graphic design that I found on Google and want to use it on a counter.
Can anyone tell me if it's possible to do that way or do I have to use only these materials which have given in Archicad.
In the Materials Dialog, you can duplicate an existing Material and change that. You can assign any Texture file to it that is in the loaded libraries.
Then you can assign this newly created Material to the proper parameter of the Library Part.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac29
