Visualization
Edit lights on artlantis
How can I make the efect of light in a rectangular lamp 3500ºK for office? for example, if I´m working on archicad I turn on the lights on settings. Now on artlantis/window/edit lights there are 3 kinds of light but no one fits on rectangular light. Does anybody knows the trick?
thanks
5 REPLIES 5
Dwight
You will fake the light with a glowing surface that doesn't cast light at all - creating the fluorescent panel - say, the neon shader.
Then put a 3500 degree omnidirectional light on its face - or a wide floodlight if it is recessed - and adjust the start/end of the light force to not overexpose the ceiling.
Dwight Atkinson
Dwight, I appreciate your tips. but I found other way for the lamps of 3500K I have placed two center omni light one in each end. and I have created the wished effect, just inceasing the intensity of light.
thanks
Dwight
Can you please post your result?
Dwight Atkinson
For the lights from the aisle of the picture (right) I cant make a good effect of light I´m trying increasing and decreasing the inscidence of light, on expert lighting, I hope somebody help me with this
5 min overpaint results
