2026-07-21 11:04 PM
Hi all - Im just curious, for those using Enscape, if anyone has found a workflow for saving favorites that can be shared as an office library to be used between projects.
We have just a couple dozen or so trees and plants we have found we like to use. Right now it's just a list that every time I open a new project i have to search the library and favorite. Is there a good way to create an office library?
Thanks!
Thursday
I find that Enscape dumps a lot of assets and textures into the embedded library and I regularly have to remove them and place them in a linked project library. They work fine once they are copied over and the library is reloaded, but it is a tedious process. An option to have the Enscape Library already loaded would be great but it would probably be huge. I would imagine you could create an office Enscape library fairly easily though, especially if you only use a few of the objects and textures.
Another thing that would be nice is to have an improved 2D view of certain objects, as the orange blobs look terrible and you have to duplicate elements to represent them in drawings and renders.
Thursday
You can link Revit families to Enscape assets.. We really need the same for Archicad, no idea if this is planned or even possible with objects.
Thursday - last edited Thursday
Archicad 27: Graphisoft Building Together - AEC Magazine
It was meant to be a feature in archicad 27!
'It’s now possible to map any Archicad object to any high-poly Enscape asset, giving users the best of both worlds' 🤔
Thursday
Being able to have the Enscape library essentially living in our AC object library would be awesome.
They probably took the Dev off of that feature and threw them on the AI slop features no one asked for...
