Exterior Lighting Problem
Hi guys i have a bit of a problem getting the exterior lighting to work, interior is no problem but i am trying to use SPOTLAMP GROUND object n the external balcony shining up at the building wall.. but i can not get it to work, the lighting cone shows it hitting the wall.. but no luck!! light is on, 100 percent intensity yet there is not a trace of light coming from the object??? anyone can help it would be great
Thanks
1 Reply 1
Dwight
I would be your helper on this except our library doesn't have that light source - by that name, anyhow.
I expect that you have placed the source behind a solid element.
Use the Light Cone Up and let me know how that works.
Post a screenshot.
Dwight Atkinson
