2009-01-08
12:08 PM
2023-05-11
12:18 PM
Noemi Balogh
2009-01-09 04:15 PM
2009-01-09 04:33 PM
2009-01-09 04:42 PM
2009-01-09 05:37 PM
Johnson wrote:Dwight covers this or search for "undersun" here.
Sorry, my comment was quite general. I ve attached an image of the render I m working on, as you can see under the canopy its really dark.
I have turned off the archicad sun, and I am using the sun object which is set at 75%, I have the Sky object on, and another sun object acting as the under sun.
I did try to put a general light under the canopy but it then made it all look to bright.
I Really, interested in what sun object settings ect other people use and how they position them. I have got the '' Lightworks in ArchiCAD'' book by Dwight, and have read some of it. But the section about external renders is quite sort.
Any comments or help would be really appreciated.
Cheers
John
2009-01-09 05:41 PM
2009-01-09 05:52 PM
2009-01-11 07:42 PM
2009-01-13 01:09 AM
Peter wrote:This is one of the most helpful posts I've seen on this subject. I have a question to add. Should the "get model data during rendering" checkbox be checked?
Looks pretty good so far!
Firstly I'd recommend using the built-in sun instead of the Sun-object for the main lighting task. I'd try setting it quite brightly to start with at 150% and then back it off if it is too much when combined with the sky. Set it to 'Realistic Sun' with Shadows, Number of samples 100, and a Diversion angle of 0.50. This will give you nice crisp shadows.
Make sure camera and ambient are turned off for the moment.
Try setting a Sky-object to 'Realistic Method' with the number of samples at around 300. This will slow the rendering down a fair bit, but it gives a better 3d feeling. You can reduce the no. of samples to preview the render; it will just look more grainy. Have this set to mid power to start with (40-50%)
Most importantly, make sure you use a very-slightly-yellow colour for the sun and a very-slightly-blue for the sky.
Don't forget to set the location and north point correctly in the main sun settings if you need it accurately lit. The built-in sun and ambient takes their colour from this dialog box also.
The undersun should be set fairly low powered and it colour should probably be a light blue also.
If the render is still too dark try enabling the built-in ambient light to boost general light levels.
Set the Anti-aliasing to one notch below best for previewing the image. It will use all the cores in the machine to render. 'Best' only uses one core, but looks better.
2009-01-13 03:30 PM
Wrathchild wrote:To quote the Help file -
Get model data during rendering process: Check this box to allow two processes to proceed simultaneously when you execute a PhotoRendering: ArchiCAD will analyze model data at the same time that it generates rendering effects for the model. As a result, the rendered model might take longer to appear in full on screen, but the process will require less memory.I've no idea if it makes any difference, I've never tested it!
