Visualization
Foggy LW renderings
Just upgraded to AC 9 and have begun experimenting with Lightworks.
When i do renderings they look fine as they are rendering, colours are crisp etc, but just as it finishes all the colours wash out slightly, as if covered by fog, leaving the final render quite dull.
Dose anyone else have this problem, or even better an answer as to how to stop it?
And before you say it Dwight, the books getting ordered very soon......
10 REPLIES 10
It is not easy to diagnose your problem but you can start with those:
1. Check if you don't have a fog in your foreground settings
2. Make sure the image brightness is at "normal" level
and here..
Those are the setting that i have already which is why i am a bit stuck.
I have attached a couple of screenshots of my settings to see if anyone can see something i cant.
I'll also attach a picture of the rendering in progress and when finished to try and show what i mean.
Thanks.
settings.....
settings 2......
during and after - hopefully you can see what i mean with the colour difference....
Ok, some things first:
1. If you're expecting the best from lightworks by setting everything "ON" and at "100%" than you might get dissapointed. If this would be so obvious than Dwight wouldn't have to write the book about it. In the mean time try this:
- turn off sun
- set ambience at 50%
- turn off camera light
- try to use combination of 2 skyobject + sunobject
2. If the model is huge and shadow's quality is not your priority (but time is ) than - no lamps, no camera light just internal sun.
3. Settings help you get the reasonable result in a reasonable amount of time, but you need to make choise what is more and what is less important in your presentation.
Hope this helps a little.
Cheers
You are of course right, setting everything to 100% isnt the way to achieve the best renderings - the settings i've shown above were me trying everything i could think of to try and get rid of that foggyness... but with no avail.
I'm still stuck as to why the image changes at the end of the rendering, any further thoughts?
-Go back to last tab- Brightness
-Check last radio button- paint overexposed surfaces with
-Change colour to pure white
-Click on apply button
