Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Visualization
Render your model with built-in or 3rd-party solutions
GDL object assistance
Hello, I'm having trouble locating a perforated steel panel/sheet GDL object. I've resorted to importing a texture and throwing a translucence characteristic to it in order to mimic a perforated panel. Any other suggestions on either creating a panel or a place to DL one. Thanks.
2 REPLIES 2
Dwight
See:
perforation for the nation
Dwight Atkinson
Dwight
i also note a texture image in the Archicad 11 library "Metal perforated Alpha.png"
This implies that the file contains specific transparency qualities but it does not since it is saved incorrectly in the library.
PNG files support transparency masking without alpha channel since they can be saved as three channel files with transparent areas - like perfs.
Try using the attached file as your texture in the internal engine material dialog and checking transparency under alpha channel effects.
Dwight Atkinson
