Visualization
GSI: Grime Scene Instigation
Dwight
LightWorks: Materials: Color: That second image can be used as a large sized mask to make progressive mess near the bottom of a wall. All sorts of surface variations can be induced this way.
I needed to prove it could be done.
Dwight Atkinson
Stephen Dolbee
Very cool. Before and after pressure cleaning!
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
stefan
Can the mask be used to mix between two materials?
Do you have seperate control over the mask?
Is the mask black/white or greyscale?
Does it rain in Canada?
Archicad-user since 1998
my Archicad Book
Dwight
1: Mix? No> The color mask uses the red channel of a texture map only to apply a color you specify to the base texture.
2: Mask control: size and proportion only. other adjustments must be done in Photoshop.
3: mask color: RGB, but it references only the red channel.
4: Canada weather attached, Oceanfront pool opens tomorrow. yay.
Dwight Atkinson
