Here is part of one of the 8 elevations (45 degree wings) of the house I'm working on.
The architect has specified corner boards, square log siding, then board and batt, a trim board, and finally corten (corrugated steel - the homeowner sells it and wants it). Actually, there will be a short rock wainscoat at the base modeled as a rock wall as well.
In the screenshot, I selected the walls so you can see the hotspots and how the siding fills just don't align with any wall breaks. (One wall break is due to SEO and interior issues.) This is why I'm using this concept (trick/tip when it works!) of one big fill to map onto multiple walls (via a single material and common origins).
The wing in the foreground has a single fill with the linework shown associated with a material, and both walls are assigned that material. The origin for both walls is set to the lower left corner of the lower wall.
A similar fill and material is mapped onto the three walls in the rear gable end, origins all set to the lower left of the lower wall.
When you view this model in 3D with the internal engine, you get isometrics with these fills, something not possible if I had just done the linework on top of the elevations.
This is how it is supposed to work anyway.
š
My first message points to the problem when it doesn't work ... my fill is stretched horizontally and no longer aligns properly. My batts become fat, and the corner boards 'fall off' the wall.
š
