Visualization
How can I render this?
I keep getting the message "Not enough memory to render" message. The problem is that the structure is huge. This is the first commercial project I've done and it just so happens to be massive.
I attached the 2 sections that I tried to render and got that message. I'm only trying to render with Method: final, and AA 2/3.
Is there a way to make it render?
Thanks.
Outside of Diamond Pointe
View from lobby looking up 15 stories to where the skylights will be.
Promo, just for the heck of it.
6 REPLIES 6
ok! try to remove anything that wont be visible to your rendering. furnitures interior stairs even walls. try to make a second file where you will have only the 3d model no layouts no details nothing just the 3d model. i hope u have more than 2giga of ram . i hope this tips will help you.
in the lightworks rendering setting menu, make sure the box that says : "get model data while rendering" is ticked
that will solve it
that will solve it
This did not fix it, I still get the same message.
See these articles:
http://www.archicadwiki.com/LightWorks%20memory%20usage
and
http://www.archicadwiki.com/TechNotes/How%20to%20Check%20Virtual%20Memory%20Usage
Something there may help. I don't think it would matter, other than speed, but upping your memory to 4 GB would help the speed of your machine with a large model like that.
AC 29 USA and earlier   â€˘   hardware key   â€˘   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Does it help to reduce the refraction setting of the glass perhaps? Check in the material settings dialog > Lightworks Shader tab > Reflectance > Glass > Refraction. Try a value of 1.0 and see if it makes a difference.
vfrontiers
adamvk wrote:
that will solve it
Fix 1: Get artlantis
Fix 2: Get model into 3d Window... save as Object.. be sure to check the AS BINARY button. RENDER the object only...
Fix 3: Get more ram
f
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
