Visualization
How can I reset the Photo Rendering Settings Palette?
Minh Nguyen
Thank you for sharing the issue and I am very sorry about it!
This is a typical issue where the PhotoRendeing dialog was dragged out of the screen. Sometimes a computer restart may help with the issue!
If it does not, I would like to suggest trying the following things:
(your account on Windows needs to be Administrator type, and ARCHICAD need to be closed before taking these steps)
- Go to C:\Users\[your account name]\AppData\Roaming\GRAPHISOFT\ARCHICAD-64 XXXX\ then delete the file ARCHICAD Basic.prf
If it doesn't work, then:
- Open Registry Editor by right-clicking on Start button, select Run. Type regedit then press OK.
- Go to the following directory: HKEY_CURRENT_USER\Software\GRAPHISOFT\ARCHICAD-64\ARCHICAD-64 XXXX\Dialog Manager Custom Data, then delete the file RenderingSettingsPaletteRect
(XXXX is the version of ARCHICAD on your computer)
I hope this will help you with solving the problem. If you have any further questions, feel free to let me know.
Thank you very much! Have a great day!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
1 REPLY 1
I deleted the original post because it was posted by a spammer, this is why it is not visible anymore.
The information contained in this thread is valuable, however.
