Visualization
How do I set up a port so I can see it in 3D and then rendering, ajar?
Thank you
David Maudlin
Giovannino60:
Look at the door settings for something like 3D Projections > Opening Angle. The name of the parameter and its location in the settings will depend on the door you are using.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Can't find the button where you vary the opening angle? Thank you
I have a different language version to you and this screen shot is from 23, but it might give you an idea of where the setting is.
