Visualization
How to Import Colour Palette (.pal)
Jere
Hi, I've downloaded a colour palette from a paint manufacturer. It was under "Nemetschek" and is a .pal file. I understand the RAL goodie also uses a .pal file
I can't find any documentation on how to import these files.
Any idea?
ArchiCAD 26; Windows 11; Intel i7-10700KF; 64GB RAM, GeForce GTX 3060
4 REPLIES 4
Ricardo Lopez
Hi @Jere
You can find more information about the RAL Color System Add-On here:
https://community.graphisoft.com/t5/Project-data-BIM/RAL-Color-System-Add-On/ta-p/303650
Regards. -
M. Arch. Ricardo López
AC17-28 SPA+INT | Windows 11 | MSI CreatorPro M16 HX C14VJG, 64GB, Nvidia Quadro RTX 2000 Ada Generation
Jere
Thank you, Ricardo. Will this allow me to import other palettes?
I guess so. You can check it out by yourself. Nothing to loose. 🙂
Ry95
Hi Jere
Did you find a solution?
I have used the link above and downloaded the RAL .pal - but cant get it to work.
