How to get the realistic light show!?
Hello everybody!
I'm a newcomer from Vietnam, and I've learn to use AC11 2 weeks ago.
There some first result!
-- I wonder how to light the bottom face of an object ??? It's always seem to be dark and not realistic.
-- Dear Dwight! I realy like your book. Can u tell me how to buy it?? I've got cash only!
( Execuse me for bad English! )
16 Replies 16
And here - Using an extra Sun object without cash shadow - there's no soft shadow in the conner of wall & ceiling..... Any way - it run so fast
Dwight
When lights don't cast shadows, the rendering is extremely fast because fewer calculations are needed. The ideal is to have only one light that casts shadows....
Dwight Atkinson
@ Dwight!
What elevation for that only one light ???
Dwight
Somewhere theres music
How faint the tune
Somewhere theres heaven
How high the sun?
Dwight Atkinson
Nice renders! as for your first question about lighting the underside of the objects, have you played around with the pipeline/ Graphisoft Emission shader? It works a bit like Max's self illumination settings, it just lights the material without actually producing any light.
Dwight
Excellent suggestion, but that approach tends to make materials uniform in light reaction.
They lack modeling.
You'll also need a different material for shade versus well-lit and this can mess up the quantity calculation chart.
I find the "Undersun/Hellezon" approach copes with any dark shade condition without adding rendering time.
Dwight Atkinson
Sukhoi wrote:
Thanks "Whatever" for your guider.
I find out 2 way to light the bottom face of an object
1) Use an extra sun - without cash shadow
2) Use Realistic method of the " Sky object"
- Sample 200 ( duo2.8, 1gb ram) , may be more on stronger system.
The second way make picture look more realistic than the first - especialy in the conner of wall&ceiling.
Hope to sharing the skill with every body.
Here are some test - same V-ray presentation
(Execuse me for bad English)
Sukhoi, looking at your exterior view I suggest more archictecural detail for the facades would add to the realism. Also the roofs look too thin. Interiors are great though.
