How to learn Artlantis
I am using ArchiCAD for a long time, and i was quite happy with its own render(lightworks), but I got Artlantis, and as I can see, it is mouch better.
My question is how to learn Artlantis, maybe some tutorial?
thx
6 Replies 6
Dwight
As a long time Artlantis user, I suggest that after you do the basic Artlantis tutorial that you just play with it.
Make small renderings. The real-time preview helps a lot in anticipating the result.
Dwight Atkinson
Thomas Holm
Artlantis' user forums (abvent's website) are quite helpful too.
Rafal SLEK
Videotutorials You'll find at
http://www.artlantis.com/community/tutorials/#
or in your Tutorials folder after installation.
They are quite useful - after looking at them only practice is needed...
Best
Rafał
//Archicad since 4.1 version
//MacBook Pro Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/macOS 13.6
//Razer Intel i9/2.5GHz/32GB/Nvidia RTX 3080/Windows 11 Pro
//ArchiCAD Collaborate
I allready saw those tutorials...
I need some things about ArchiCAD+Artlantis...
Is it posible to make renders with Artlantis which are as good as in max?
Dwight
The simple answer is "no."
Artlantis is designed to create beautiful renderings simply and makes certain functional compromises to do so. It is a medium-level product. You can quickly achieve good renderings with Artlantis and it is a good teaching tool because of its simple interface and preview capability. However, to mention only two shortcomings:
-- Artlantis lacks the material surfacing sophistication that Max users can access.
-- its radiosity, while fast and beautiful, lacks control over "caustic" and other subtle light energy effects that the higher quality rendering applications have.
Dwight Atkinson
Best way to learn is to read Artlantis forum & test yourself a lot.
Here's a little artlantis R test i did recently using a mixture of artlantis shaders & external texture maps.
