Jan Mi
How to make a surface transition from cobblestone to grass
Cheers, I want to make a paved pathway that is cobblestone in the middle and as it reaches the borders it has more grass.
I thought of two ways I could do it:
1. draw the pattern I want and create a slab with a hard surface and delete the areas for a grass mesh.
2. make 3 different surfaces in photoshop with different percentage of stone to grass ratio.
Different stone to grass ratio references:
Something like this surface would be ideal:
Should I use any of these two methods or is there a better way to do it?
p.d. The path has curves, so I think the surface method might match properly in the rendered view
macOS 26 (Latest Build) - Archicad 29 (Latest Build)
1 Reply 1
Pato99
Under the 'Density Texture' option of the grass select image and use a black and white map, white where grass grows and black where it doesn't.
Have 3 materials (and slabs) Full Grass, 25%-60%, Full Tile.
It shouldn't be impossible.
This might be of use to you.
https://www.facebook.com/geometra.pesce.patrick/videos/1339738926083208/
Versions 10 to forced subscription
Please vote for Constant thickness to mesh What will GS do when they reach 200 votes? Less than 30 votes to go!
Please also vote for my whishes, as 200 votes in 6 months is an impossible target, don't be a bystander:
1. Relative file locations | 2. Auto text in Publishing | 3. Model types to Grasshopper | 4. Index Numbers in Search | 5. Step through Elevations | 6. Rhino is better than ArchiCAD
Here's a reminder of what you're voting for: Wishes Delivered
