Display malfunction of Graphisoft ID dashboard
Learn more
ncorticos
How to remove layout from a view?
Eduardo Rolon
If you are referring to the "gold" page layout you need to either delete those elements from the applied "Master Layout" (See the one with the dark gray icon) or create a new empty "Master" and apply it to the layout.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
ncorticos
 Solved! Thank you!!
