How to render out a color mask with ARCHICAD
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2018-07-12
01:13 AM
2023-05-11
11:37 AM
Noemi Balogh
So to ease your pain, I decided to show you how it's done in ARCHICAD ! Yes you can and it is VERY easy, after you watched this quick coffee tip, you will pull your hair out and say to yourself, why did I not think of this
This option has been there ever since Graphisoft introduced CineRender. Ok it's not really an option, it's a solution but see for yourself.
Quick coffee break tips with ARCHICAD come on a weekly basis subscribe to the channel and click the bell to receive automatic notification.
Enjoy! Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-25 09:49 AM
Or is there some setting i've missed?
//Karl W
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-26 12:16 AM
- in Photoshop increase the Tolerance of the selecting tool, sometimes you have to play with numbers a bit.
- in Photoshop use: select - color range, click on a color you like to select and move the fuzziness slider
- in ARCHICAD, move the sun so it "hits" the corners at 45 degrees, this will distribute the ambient shadow ( or no shadow ) equally either side of your model. Obviously that depends on where the camera is.
www.asmtechbase.com
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-26 03:00 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-26 09:35 AM
Karl W
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-26 09:46 AM
Karl wrote:
The objects cast no shadows on other objectsbut they still have some kind of self shadowunless you turn off the sun completely.
There is also an option for "Shade surfaces using sun" when you are using the Vectorial 3D engine (which you should be for this).
That should save you having to set the sun at 0%.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-26 10:04 AM
Karl W
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-26 10:46 AM
Karl wrote:Of course - I wasn't really thinking this would have no effect on the render.
The setting "Shade surfaces using sun" is for the 3D window. It seems to have no effect on the rendered result.
I just had a quick try (I haven't set up contrasting material colours though).
In the render settings, use the 'Basic' rendering engine.
Turn the textures off.
Turn the sun off.
You can't turn the sun and lamps off but turn off the lamp shadows as well.
This was my result.
Basic colours and only the slightest of shading (maybe the ambient light will have an effect on this?).
You can increase the brightness if you need to.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-27 12:48 AM
I like your option of turning off the sun that works better. At the end of the day this is as good as it gets in ARCHICAD.
If you saw my earlier post with how to select in Photoshop, there is absolutely no problem selecting any color, even if you have a slight shade in it. If it is not taking all of the color mask, then just click again in the slightly different shade with shift click ( windows ) , which adds on and it will select the rest of the desired color mask.
To match your main textured render, the most important part is to render out a high resolution color mask, at least 4000 pixels. Because of the settings and no texture this won't take very long.
www.asmtechbase.com
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2018-07-30 03:32 AM
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
