Visualization
How to smooth edges when rendering objects
Hi
I have just started using Archicad. Have been using some simple programs before. I cant mange to get smooth edges when rendering using Lighworks, please see the attachement. Am I doing something wrong or is the model simply not good enough? I was hoping to get it much better. Thanks
4 REPLIES 4
your models in scene are modeled to have less polygons !
You will need to find other models,
or if these have RESOLUTON (Res) option in gdl rise that option to higher value.
If u wannt to model bannas and apples u better do that in some other program cos archicad is not for that....
As Neck wrote.... depends on the resolution & no. of lines ....look the differents...
Thanks a lot Guys. Fruit is just an example. I will try GDL option. The thing is I will be using a lot of free objects rather than creating my own ones.
Thats very helpful, Thanks so much again.
Solved ! . The object I had was converted from 3ds with low resolution or something. Found a new plugin, an look on the difference
Thanks for help šŸ™‚
