Feanix
Imported morph in Twinmotion is only visable from one direction
Hello!
I got a problem with the visualisation of a project.
In the pictures you can see my problem.
You can see the morphs (These are membranes in real life) are only visable from one side.
I tried every way to save the project as .fbx and every way to import it in Twinmotion, but it stays this way.
What can I do about it?
4 Replies 4
KenMcN
I think you need to tell the material to be 2-sided. Sorry, can’t remember if that’s in the material definition or the object settings (but I hope it’s the material, so you can change them all at once).
Hope this is right and it helps.
Kenny
V25 & 26 (fully patched); Mac Ventura, MacBook Pro M1 Max
Feanix
Im gonna try that. Altough I dont know if you can do that with a morph.
Edit: Nope, doesnt work. There is no way to tell the morph its two sided.
mikas
Not sure you tried it allready, but I think KenMcN ment you should set it up in TwinMotion, not in ArchiCAD. I have had these situations too and I did solve them by choosing two-sided material in TwM for the object.
HTH.
AC28, Rhino8+Grasshopper, TwinMotionMac Pro 6,1 E5-1650v2-3,5GHz/128GB/eGPU:6800XT/11.6.5 • HP Z4/Xeon W-2195/256GB/RTX4080FE 16GB/W11ProWS
KenMcN
Sorry, thought I'd replied to say that as well, but it must have gotten lost. Yes, the material needs to be edited in TM , rather than Archicad.
Thanks Mikas
