2025-05-30 09:21 PM
Hello!
I got a problem with the visualisation of a project.
In the pictures you can see my problem.
You can see the morphs (These are membranes in real life) are only visable from one side.
I tried every way to save the project as .fbx and every way to import it in Twinmotion, but it stays this way.
What can I do about it?
2025-05-30 09:30 PM
I think you need to tell the material to be 2-sided. Sorry, can’t remember if that’s in the material definition or the object settings (but I hope it’s the material, so you can change them all at once).
Hope this is right and it helps.
Kenny
2025-05-30 11:08 PM - edited 2025-05-30 11:46 PM
Im gonna try that. Altough I dont know if you can do that with a morph.
Edit: Nope, doesnt work. There is no way to tell the morph its two sided.
2025-06-01 07:56 PM
Not sure you tried it allready, but I think KenMcN ment you should set it up in TwinMotion, not in ArchiCAD. I have had these situations too and I did solve them by choosing two-sided material in TwM for the object.
HTH.
2025-06-01 09:04 PM
Sorry, thought I'd replied to say that as well, but it must have gotten lost. Yes, the material needs to be edited in TM , rather than Archicad.
Thanks Mikas
