‎2014-05-03
01:03 AM
‎2023-05-26
02:58 PM
Rubia Torres
‎2014-05-06 02:53 PM
KeesW wrote:Yes creating a new material will create an attribute with a new attribute index number.
If you create materials with different names, doesn't AC automatically create unique numbers for it.If so, do you also need to allocate different colours or will the distinctive names do the job?
‎2014-05-06 07:47 PM
‎2014-05-07 04:23 AM
JaredBanks wrote:This will work for profiles stacked on top or next to each other.
I was thinking about making all my Complex Profile rectangular sections clipped 1/16" or less at the corners. The angle will create three lines at each joint but it'll be so small it'll merge into 1. That works for columns and beams, but not roofs or slabs. since CPs don't work for those.
‎2014-05-07 05:31 AM
