Internal engine rendering: shadows don't show (sometimes!)
I've been doing Photorendering using the internal engine and sometimes there are no shadows in the rendering. Sometimes there are. Very strange.
I fooled around and found that if I closed and then reopened the 3D window and immediately did the rendering the shadows did show up. If I changed the rendering type to Lightworks and back to internal engine, keeping the 3D window open, and then rendered it, the shadows were nowhere to be seen.
Have you experienced this? Is there to avoid this weirdness?
0 Replies 0
