Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Visualization
Render your model with built-in or 3rd-party solutions
Is this panel glowing
Dwight
like a backlit sign?
Dwight Atkinson
8 REPLIES 8
Is this a question? If so. yes it is.
Dwight
okay, thanks.
Dwight Atkinson
Eduardo Rolon
I might need some glossiness since I have not seen a matte backlit frame.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Dwight
Thank you. I know what you mean.
At my age, most of my glossiness has rubbed off.
In this case, there are no light sources to be reflected - the study is all about projected light, so, next time, acrylic covering for sure.
Dwight Atkinson
__archiben
it is - but what makes it slightly ambiguous is that there is no 'frame' or edge condition: the tiles and glowing panel meet too perfectly. although i'm sure it could be detailed in such a way, reality isn't often so perfect.
b
b e n _ f r o s t
Dwight
I was just working with the light issues, but that's a good point - anybody who's NOT a goob looks for supporting evidence. Thickness counts.
I'm getting as bad as the blobitecture guys!
Dwight Atkinson
__archiben
thickness, aye! it's same as the woodgrain principle - it bugs the hell out of me when i see the grain running vertically across a beam!
b e n _ f r o s t
Dwight
How could they ever let that happen! The same with window sashes, eh?
Goobs!
Dwight Atkinson
