Known shadow bug?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2008-01-27
09:42 PM
‎2023-05-11
01:42 PM
Noemi Balogh
thanks
1st is shadow not generated
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-01-27 09:43 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-01-27 09:45 PM
This can kind of make you nutty.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-01-27 10:07 PM
Thanks,
Doug
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-01-27 10:14 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-01-27 10:15 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-01-27 11:44 PM
ArchiCar 1 from Alfavilla ArchiCars. It's even weirder than i described. I first made the brick sidewalk, then the drive. I put the car on both and it case a shadow on the brick, but not the drive (half the car made shadows, the other half did not). I thought it must be the slab settings, so I changed everything I could for the drive.. no change, and then injected the same settings from the brick to the drive... None of that changed anything. I deleted the drive, made the sidewalk bigger.. etc. The only thing that seems to influence it is moving the car partly off the drive, then I get a shadow. They are set the same height. It weird that the shadow on the drive from the house becomes on and off, with the car.. or so it seems.
Notice in the top rendering, the house is casting a shadow on the car, but not the drive.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-01-27 11:53 PM
And so it goes. While I can see that Archicad might reject the shadows from a complex object like a car, my simple boxes were also affected.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-01-28 02:39 PM
Rick wrote:I see this too sometimes, but with walls or roofs in elevations with cast shadows. Out of the blue one roof or wall will not cast a shadow, which often stands out really badly. It's very rare thankfully, but I don't have a definite method for fixing it. Sometimes just looking at the element settings does the trick. I suspect it's a precision problem deep in the bowels of ArchiCAD's polygon-clipping procedures, i.e. a bug, as you surmised.
I am going to post several renderings. Notice the shadows from the house and the car. Sometimes you see the shadow, somethings not. [...] That seems like a bug to me, so I am curious if this is known or not.
Central Innovation
