LW Anomaly
Here's an odd one. I've been tweaking some custom curtain wall doors for a client and got this rendering. It's probably just a curiosity but maybe it's something to do with the material settings. I haven't tried figuring it out yet.
4 Replies 4
Hi Matthew,
Cool effect!
I would guess the glass is refracting the edge of the door making it appear thicker at the far edge. Have you tried using a glass material with less refraction, perhaps less than 1.0? Or maybe try adjusting the angle of the open door slightly?
No, I haven't had time to play around with it. Too busy forcing the custom panels and CW labels to behave (not an easy task )
The glass is an AC default. When I get the chance I'll try one of my own materials. It does strike me as kind of interesting if it can be controlled.
David Maudlin
Matthew:
One place to look in the material settings is Reflectance > Mirror > Mirror Factor. I have found in my work that I need to change this setting depending on whether I am rendering an exterior or an interior.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Dwight
And here i am thinking that your 'anomaly' is the greenish stripe on the middle third of some mullions.
Duh.
Dwight Atkinson
