Visualization
LW Lighting
I have used sun- and heaven- and window object, and I shut off the sun in 3D Photorealistic option.
Camera 100%
Ambient 100%
Lamp 100%
If the intensity of camera is 100%, than the window is too much sunshine (please see the picture.)
But under 100%, the inside room is very dark.
Can you help me?
18 REPLIES 18
Dwight
Lamp cannot be 100%
Turn off Camera lamp
Put some lighting in the room to compensate for the bright sun.
Dwight Atkinson
Turn off camera lamp
ambient lamp 100%
Window lamp 80%
Sun lamp 70%
heaven lamp 70%
and than...I can not show such like thing to the client.....
Dwight
send me your model and I will fix it.
Dwight Atkinson
OK!
Dwight
look in private message for address
Dwight Atkinson
Dwight
the five minute fix:
four minutes: open file - translate obscure German words: flugelfenster - a musical window, kunstkopf-a head that hears , schvanstuker - sex education helper.
one minute:
--Added windowlite behind camera [in an actual opening]
--made sun and windowlites in sun direction have yellow light and at full power, not blue and black as you had placed.
Boosted all light power.
Black is a bad color for lights since only cats can see it.
Make sure all the lights that you place are "ON."
It is still a little creepy - perhaps add a general light source under the floor - this is not stopped by elements and will light all surfaces from below.
Dwight Atkinson
Sorry for your three minutes
Great help through your one minute.
I changed color (very important, still stupid color...)
Added windowlite behind camera (80%, over 80 was too much)
Sun and windowlite full power
I turned off heavenlite.
Tomorrow after sleeping I put some general light back to glass brickwall, and under the floor.
I hope, you take a look.
Than you.
So, I woke up again.
This time, with General light on the floor and back to glass wall regarding sugestion of Dwight.
Sunlite 30% with direct sun direction
windowlite 100%
What kind of color for lite did you take?
I like your color, it looks very soft and real.
Can you teach me?
