2005-06-07
04:20 AM
- last edited on
2023-05-11
01:24 PM
by
Noemi Balogh
2005-06-07 05:05 AM
2005-06-07 05:41 AM
grenderer wrote:More frames between cameras.
How do I make a longer, and much slower Quicktime movie in ArchiCAD 9?
2005-06-07 06:09 AM
s2art wrote:OK, thanks. Will more cameras (keyframes) in my path help as well?grenderer wrote:More frames between cameras.
2005-06-07 06:32 AM
2005-06-07 06:39 AM
s2art wrote:
More keyframes will give more control of path (if you need it). As for stalling at each keyframe, this might look a bit odd if you move to a point, pause, move off again, pause. Maybe if you pause, then start from a different point (i.e. new path, probably with a pause at start too) and edit scenes together.
Check this thread from Dwighthttp://archicad-talk.graphisoft.com/viewtopic.php?t=6665 , and if it doesn't put you off completely try the combination with "quality stills" idea. Sounds good to me, haven't had a chance to use it yet myself.
