Rob
Light Cone
Nik,
unfortunately, AC internal light definition REALLY SUCKS at the moment, it's obsolete, clunky and doesn't even support LW to the full extent of its potential.
However, to answer your question, you could use additional uplight or tweak the actual lib part in GDL by adding a new light source in it.
::rk
2 Replies 2
Dwight
or just make the fixture glow by making its material:
1: Reflection: constant: white
2: Pipeline: Graphisoft Emission: white: Attenuation 0
Dwight Atkinson
Dwight
and for the surrounding light - the most versatile light is the wall light indirect that makes diffuse glow around itself..... scroll to the bottom of the parameter list.
These candles use that light
Dwight Atkinson
