Light box
How can I make an image look as though it is back lit with lightworks. I create a material using a jpg as texture and apply it to e.g. a wall. I've tried no end of messing with the reflectance and transparency, but can't get it to look right. Any ideas.
2 Replies 2
Dwight
If you are working with LightWorks, you'll need the fantastic "LightWorks in Archicad" book available from me directly.
The answer to your specific question is:
1: Create the image as a material.
2: Make the material have "Constant" reflectance.
3: Adjust the image in Photoshop to be lighter - simulating overexposure.
Study the "Align 3D texture" command to precisely position your image on a panel.
Dwight Atkinson
Dwight
Did this solution work for you?
What kind of result did you get?
Dwight Atkinson
