‎2007-02-14
06:18 PM
‎2023-05-11
12:27 PM
Noemi Balogh
‎2007-02-14 06:53 PM
aggie463 wrote:
Is there a way to do a LightWorks rendered elevation and place it in the same manner you place any other drawing on a layout with its own title and scale?
‎2007-02-14 07:01 PM
‎2007-02-14 07:30 PM
aggie463 wrote:You can drag a Camera view into your View Map, then place it on a sheet. Since it's a raster image, it will not be to scale.
‎2007-02-15 01:16 AM
TomWaltz wrote:You can also use side axonometric views to give you an accurate elevations. The state of these views will be stored as to when you saved them.aggie463 wrote:You can drag a Camera view into your View Map, then place it on a sheet. Since it's a raster image, it will not be to scale.
‎2007-02-15 01:04 PM
