aryastark
Lights not showing through glass - window
Hëllö
Any type of light doesn't appear through the glass.
How can it fix?
Thankś.
lights not showing?
Ver: AC23
Operating System: Windows 10 64-bit
Processor: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz (8 CPUs), ~2.6GHz
Memory: 16384MB RAM
Card name: Intel(R) HD Graphics 530
Chip type: GeForce GTX 960M
1 Solution
Lingwisyer
Guru
Try increasing your Ray Threshold?
Render Settings => Options => General Options => Ray Depth / Ray Threshold
Ling.
Go to post
3 Replies 3
Lingwisyer
Guru
Ling.
aryastark
also opening visible lights from light setting worked.
thanks.
Ver: AC23
Memory: 16384MB RAM
runxel
Also please be aware that the preview is actually lying to you sometimes....
Some settings are hardcoded in the preview so it doesn't take to long to render.
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
