‎2007-08-27
03:30 PM
‎2023-05-11
12:25 PM
Noemi Balogh
‎2007-08-27 05:38 PM
‎2007-08-28 03:30 AM
‎2007-08-28 03:33 AM
‎2007-08-28 03:51 AM
‎2007-08-28 08:29 AM
‎2007-08-28 08:31 AM
‎2007-08-28 04:27 PM
placed a lamp somewhere, probably a skylight or a sun objectI did this, 3D, select all layers, find all lamps, total found and highlighted = 34. All 34 are accounted for and looked to be in the correct position.
Could you tell me which lights you've used for the Red and Violet lights?The Violet is the Wall Lamp 05 10 on the patio right side and the red is in the kitchen, Halogen Recessed 10.
Some light fixtures also had an optionI looked through the parameters and didn't see anything like this in the lamps I'm using which are:
‎2007-08-28 04:56 PM
‎2007-08-29 04:20 PM
If you call up the 3d window window and SELECT ALL LIGHTS, do you get a count that matches what you know to be lights?Yes, there are only 34 lights in the model, when I do a 3D (on show all layers view) and select all it comes up with 34.....
