Lightworks turns black
Hey do you guys have any ideas why my light works materials would be turning black?
my Internal Engine and Open GL look the way I want them to.
I'm confused....
11 Replies 11
Dwight
You mean that they worked fine before and turned black today or new materials that you are making?
I think they call this the Jagger Effect.
Dwight Atkinson
It is new materials I am making that turn black.
I dont know what settings I have changed. None as far as I can tell, but, that is most likely not the cas, or I would not be having this problem, and of course I need to have this stuffdone by tomorow.
Jagger effect aye?
Meister?
Dwight
The Mick Jagger Effect oh young one.
When you make a new material using the internal engine you must MANUALLY TRANSFER THE VALUES to LightWorks
With the LightWorks Material Dialog Open find the "Match Internal Engine" Button.
Dwight Atkinson
I thought you must have ment something besides jagger meister.
Um, so I know that I need to manually set it to be the same, and when i do that is when they turn black.
Dwight
Where are you saving your textures?
When you look at the material in LightWorks, does the file name appear in the right places?
Dwight Atkinson
mmm I will open it up and check, I'm not really sure where I would find that info though.
Dwight
Show the dialog for Graphisoft Masked Image.
Dwight Atkinson
I noticed that my custom maerials are loaded twice, would that matter?
I am waiting for it to unload one of the libraries now, my computer at home is super sucky slow, so this is a proccess.
K, well my textures are all loaded only once now, and they are still black.
By Graphisoft masked image dialogue do you mean the settings to the right - Under Set Perameters?
I see now that next to file name it is blank.
I am going tochange that now, see what happens.
I have never paid attention to that before, so I don't knwo if there is supposed to usually be anything there.
